Can some 1 help me find the revlimiter for this file?
Is it locaded right in front of the main spark maps?
which is:
#16E6 DEC=86
#12C5 DEC=86
located in front of the WOT sparkmap
#1367 DEC =96
Original Rpm limiter seems to be just past 6100 rpm.
I can remember that for the VR6 ECU's I did DEC * 70 to get the RPM limiter..
I can upload the original file, but you can alsofind it in the download section.
RPM limit for BMW E30 325e M1.1 2.7L hw018?
http://www.tunerpro.net/download/bins/B ... 30_081.bin
i downloaded this file, and modded that one for the ecu. the ecu has the same code. so i did some work before i got the ecu.
it worked in the ecu, also with modded ign maps etc..
I think i found something. guessing the foprmula for the rev limit is
DEC * 40.
adress #1372 contains DEC 172, HEX AC.
its 3adressed afther the WOT ign map.
172 * 40 = 6880.
I could be totally wrong on this one...
what is the usual posistion of the revlimiter and usual formula on the older motronic ecus?
DEC * 40.
172 * 40 = 6880.
