Display percentage as difference when comparing tables
pauldaytona
Post by pauldaytona »
Now when comparing two tables, you get the value difference, It would be nice if you could switch it to show percentage difference.
Percentage of what? The difference as a percentage of the original? The difference as a percentage of the compare? The percentage of the compare versus the original? The percentage of the original versus the compare?
pauldaytona
Mangus wrote:Percentage of what? The difference as a percentage of the original? The difference as a percentage of the compare? The percentage of the compare versus the original? The percentage of the original versus the compare?
The difference as a percentage of the original is logical because thats the source to compare to. I see a use when I compare two maps, to get an easy overview over the changes. Having the numbers(real values as is now) makes it hard to know if it is much or not.
