Hi,
i can not get connection to my ecu.
Could the last windows update cause this.
When I check the converter I get answer "cable found and fubctioning" what else can I check?
I have already hocked TP up to an other ECM, same fault.
connection to ecu
Re: connection to ecu
yesterday I have mounted TP on an other Laptop and tried connecting again. I have two usb aldl cables None works.They are recogniced "cable found and functioning" but the display stays on connecting with errors.I switched the Interface type to moates and tried to connect again.Now the display on bottom showed connected but I got no values.
What could I check too?
What ECU are you trying to connect to?
It is the 16196395.
But I could solve the problem yesterday, I burned the eprom again , put it in and have connection again!
Btw. TP is the only programm I could connect to this ecu up to now. Not winaldl or others
