J4A1 Ford Escort definitions help
Hi all,
I am pretty new to the whole Ford ECU chipping so here's my story.
I have everything I need to start tuning my Escort except the definitions. I will supply the .bin file that I have extracted along with any information I can find regarding my car to anybody who thinks that they can help me.
J4A1 ECU and the binaries have been extracted
4 cylinder
15lb. injectors
MAF sensor
SEFI
EDIS-4
If worse comes to worse I will try and learn the structure and edit everything in a hex editor but I am a LONG way away from doing that.
I have a Moates.net Burn1, F3 chip adaptor, F2A and F2E, an LM-1 with RPM adaptor, and my laptop equipped with TunerPro and Paul Booth's EEC Editor. Paul said he was going to help me with the definitions but I haven't heard back from him in almost a month.
If nobody thinks that they can decode my .bin can someone please point me in a direction that will allow me to learn to do it myself?
Thank you all for reading,
Bill
4 cylinder
15lb. injectors
MAF sensor
SEFI
EDIS-4
Bill
Post the bin up on http://www.moates.net/fileman/index.php?dir=1)%20Stock%20Binaries/Ford%20Binaries (for some reason the whole link isn't being underlined) and hopefully someone might be able to recognise parts of the code. If Paul said he would look at it I'm sure he will but your definition will be one of many he'll have to do.
There's some good eec-iv stuff here http://www.austincc.edu/cloud/tc_eec.htm especially the http://www.austincc.edu/cloud/efi/eectch98.pdf . The Mike Wesley articles here http://www.mustangworks.com/articles/electronics/ give very good insight into the eec too. The Yahoo groups for EECTuner and tweecer also are a very source of information.
Thank you all so much for helping me through this. I really appreciate it. I am passing this info along to all the people on www.feoa.net who were too chicken to dive into this without knowing where they were going .
I've definitely been looking at the right bin file To get the memory addresses I have been referring to to you need to pad out the first 8192 bytes of the 56k bin file with null data to create a 64k bin file. I do it this way so that you are dealing with the addresses as the eec has them (eec rom starts at 0x2000).
everything lol but mostly what were looking for is how you found what you have so far and how can we find what else is avalible to us through the stock ecu. alot of us would like to say disable egr or when the tranny shifts and such. asking you to figure it all out would be stupid but would asking you to teach us how to find it be stupid?
I started off by reading this http://www.fordfans.cz/download/manual/eectch98.pdf and if it keeps you interested then I found looking at (and trying to understand) a disassembly of an A9L ecu from a Mustang was next (it's possibly the most understood eec ecu). This disassembly, and a couple of others, can be found at http://www.austin.cc.tx.us/cloud/efi/list.zip
The disassemblies from the binary files (extracted fom the ecu's), were done using Bill Lawrence's disassembler, see http://autos.groups.yahoo.com/group/EEC ... r%20tools/ for it, along with other tools people use. There's a lot a hard work gone into those disassemblies (by people with more smarts than me) and quite a bit of guesswork. If you rumage around the various files on the Yahoo groups you will find some interesting stuff.
Quite a few binaries are here http://autos.groups.yahoo.com/group/EEC ... 0Binaries/ and http://autos.groups.yahoo.com/group/twe ... 0Binaries/ (you'll need to join the groups) or http://www.moates.net/fileman/index.php?dir=1)%20Stock%20Binaries/Ford%20Binaries
I'll see if I can find the egr switch but no guarantees. I'm not familiar with autobox ecu code so there's less chance of finding anything useful, I'll have another rummage when I've got a bit of spare time.
One caveat over any xdf information is that it's very much guesswork based upon assumptions made and if you start using DIY tuning then it's always at your risk. The key is not to make too many changes at once and always check to see that you are getting the desired result, if not then the assumption was probably wrong and you need to revert to the stock setting. But this is half the fun huh?
In later MAF equipped eec-iv's the WOT calibration data is fairly limited, e.g. things like aircon cut out duration, thermactor upstream air time and TPS WOT threshold. There's probably a WOT_FUEL_MULTIPLIER table too but I expect that all the output values will be set to 1.0 as this is the norm from what I've seen in other late eec-iv's.
I'm guessing that you are interested in the spark and fuel tables, these all run off load so WOT doesn't really play any part of any adjustments you are likely to make.
BTW, have you confirmed if the EGR switch is correct?
It's been snowing so all I have done is stick the chip in. Once it clears up a bit I'm hooking up my AutoXray to see what the computer tells me about the EGR. I'm also going to double check the tables against the real time data the AutoXray tells me to verify that the tables you found are in fact what the labels say.
Yeah I am only interested in the fuel and spark for WOT. I am basically just using the chip to help me run the turbo I'm sticking on there. I don't need anything too in depth just the super important stuff.
I checked a couple days ago to see if the EGR worked. I unchecked the "set" box in TunerPro and ran that profile.
My realtime data showed no EGR vacuum regulation although the EGR sensor still showed voltage. I unplugged the sensor and ran a KOER test and did not find an error code related to the EGR system.
I'm pretty sure the EGR feature in the definition you created is correct.
To clarify my post from Sunday the 21st:
I will be increasing my injector size and probably sticking on a bigger MAF depending on whether or not I max out the one I have. I need the chip to allow me to correct the fuel for the larger injectors in both WOT and cruise. I also need the spark tables for WOT and cruise. The MAF transfer function would be pretty good to have if I up the MAF. Basically the only pieces missing are the WOT bits.
I have my sea level timing set at 22.50* or more from 3200 and up depending on load. I am however having a great deal of difficulty hitting that mark when I push the pedal to the floor. I seem to be retarded around 5* from what my see level table is set to.
My ACT voltage is usually between 2.9 and 3.1 and my coolant temp varies from 160*F-210*F. Most of the time I am around 195*F-205*F.
I am using an Auto-Xray 6000 to view in real time the values given.
Any idea what is causing me to not hit my mark on full throttle conditions but otherwise in cruise be hitting the timing map very accurately? I read about a few things in the A9L explaination that sounded like likely suspects but I wanted your input before drawing any conclusions.
Also, is there a way I can change the injector size in the tuning? Stock is 14.8# and that is what I am running.
Anything on transaxle control?
Thank you so much! The more I play around with this the more I am understanding what is contained in the links you gave me. People at FEOA are starting to dig into what you have given us and are getting very excited.
AT WOT the cylinder filling is better than PT so I suspect that the 'Spark Borderline Table' is pulling timing to avoid pinging (the eec always uses the lowest spark value from the various different table lookups it does).
When tuning spark, I set both the 'Spark Altitude Table' and 'Spark Sea Level Table' entries to contain only 55 degrees to eliminate them from the final spark calculation the eec does. This then lets you concentrate on just the 'Spark Borderline Table' for your tuning. There are some other spark tables that the eec can use for the final spark value too but most people seem to ignore them.
You can change the injector size in the tune, it's just a matter of finding it (I haven't). The same goes for the gearbox control.
BTW, if you pull any other bins post them up on the Moates site and I'll do a quick check to see if the J4A1 xdf can be used on them too.
Ah I do recall reading about what you said regarding the borderline and altitude tables on a Mustang forum except the way they said it made it seem unimportant so I sort of passed it aside and forgot about it. I will make the changes tonight and give them a try tomarrow on my way to work.
Someone else on FEOA said that he opened up another Escort binary and he thinks your definition works. As it is just now starting to warm up I have not had the chance to go to the jy yet to snatch a bunch of binaries. Now that it is becoming warm again I should have them soon.
I maxed out the Borderline and Altitude tables and it did the trick. I am hitting much closer to target now; within 1 or 2 degrees. I am letting that slide because a) it is plus or minus one degree rather than always minus 5-6 degrees b) I don't know all of the other things that could be acting against my table c) I am only guessing my load.
I have been using my wideband against the OL Stabilized table and my AutoXray against my Sea Level Spark table. I have been noticing that when I am driving at about 60mph and above my spark jumps 10 degrees. My spark should be around 30* but it shows up at 40* when everything is stable. I also see the fuel table pointing at stoich but I am reading a rock-steady 17.0-18.0.
I don't know what is causing what but I also noticed at the super lean/high advance conditions my "EGR Vacuum Regl" is 0.00% and the EGR Feedback Sensor is 3.6V.
On a different note, what does the up/down axis on the fuel startup table represent? It is not labled in my definition and I don't think it's a oxygen sensor reading. I see the cranking time in seconds and what I am guessing is coolant temp in degrees C.
My lean condition was caused by my computer switching from CL to OL. I still don't understand the spark but from now on I will try and keep that stuff to the EECTuner yahoo group. For here I am giving an update on what I have done.
I have confirmed that the fuel tables, spark tables, and EGR present are all correct in the definition file. I have been able to successfully open my bin, a bin from a 5 speed escort, and a bin from special bin designed to control a race version of this engine. I plan to attack my lean condition at low load OL by looking at my MAF transfer table. In doing so I plan to both fix my lean condition and confirm the functionality of the MAF table in the definition.
Whoa I don't remember getting notified of your last post. After posting here I'm going to the Moates site to see if I posted that stuff for you. If I didn't then I will. Anyways...
I am comparing the bins of a Spec Racer Ford and a '95 Escort 5 speed. I am getting a little confused in the timing tables. I know I am looking at spark tables. However, I am seeing some negative signs on otherwise logical timing values. What do these negative signs mean?
I see them in some of the cells across most of the RPM range and on the low load conditions (between 15% and 45%).
Bill
Bill
REVIVING THE DEAD!
So I have been actively searching about the net, and I'm on feoa, about a definition for 91-95 Escort. I stumbled across this same topic on feoa and wanted in on it. I was originally going to put a microsquirt in the car, but really would like to just tune up the factory ecu.
Currently the car has a 2.0 SPI swapped into it and it runs okay enough to drive but things don't cooperate very well. I have been in contact with moates about some help and they suggested possibly getting a supported ecu and tune it from there. I was afraid the pinout from another ecu would be off, so I wanted to see if there was still some info with this generation Escort. So are there any files still floating out there that work or close to working? All the links I have seen are dead.
I noticed that in the sticky. It was ridiculous and I didn't get to see the whole thing since much was deleted. I was hoping one of the links still worked so I could see what had been done.
But I may still give it a go if I can pull the code apart. Few things though, is it possible to fully remap the fuel and ignition tables if say you turbocharged the engine? And once you find the right part in the bin and add it to the correct subject in the GUI, will that be able to properly decipher the code? By that I mean, if you find the ignition map and add it to whatever the table is called in tunerpro, will tunerpro properly understand the code so it can be read and modified?
I'm on the fence about this. If there was some help or benefit to more, then I'm more into it. But I don't want the same thing to happen from the group. Guess some people don't appreciate what all goes into these sort of things
If you have a comprehensive definition (i.e. one that is well developed with regard to the number of parameters exposed) then you can easily tune for modifications such as turbocharging.
Creating a definition involves more than finding the address of a parameter, you also need to define its characteristics. See the "Editing Bin Definitions" section of the TunerPro help file for details on how this is done.
