I noticed you posted a data stream def (.adx) for 9495LT1 $EE on Scanerpro, does this, or could this work as a aldl def (.ads) file for tunnerpro?
If so could you describe the procedure so that a non geek could do it.
Thanks, I know your busy
.adx to .ads?
- Six_Shooter
Mark, when you do integrate SP in to TP RT, will this then necessitate, setting up the dash as we need to in SP pro now, or will there be a "simple" version, sort of like what is currently in TP RT?
Don't get me wrong I do want all the features of SP, but for quick testing, or "quick starting", a simple interface would be a good idea, especially for new tuners that are still learning how to use the programs.
Ideally it would have a default dash layout, wouldn't it?Six_Shooter wrote:Mark, when you do integrate SP in to TP RT, will this then necessitate, setting up the dash as we need to in SP pro now, or will there be a "simple" version, sort of like what is currently in TP RT?
- Six_Shooter
That's what I was thinking, then be able to add/changes guages as we see fit after that.Mangus wrote:Ideally it would have a default dash layout, wouldn't it?Six_Shooter wrote:Mark, when you do integrate SP in to TP RT, will this then necessitate, setting up the dash as we need to in SP pro now, or will there be a "simple" version, sort of like what is currently in TP RT?
