I don't have time to check all the maps. You should make an XDF only of the maps that are needed for tuning. Having ALL maps on the XDF makes it look like more difficult.
you are right Revlimit but what i am trying to do is find out what does all the maps do so i can remove the unnecessary ones, like you did on the E30 ECU
The way you find out is you have to have ostrich2 emulator. Then you include all of the maps into one XDF, you don't have to figure out the load and rpm scales on all of the maps. Then you drive the car and one by one maps you hit trace to see of the ECU is reading any of the maps. Then you erase the ones that ECU never reads. So that way you only works with the maps that ecu uses.
