Data Monitor Display Bitmasks on/off
Efilive V4 had this feature, when a bitmask turned on or off it displayed a indicator in the monitor graph, this is enabled via the usual right click in the monitor window to select what you want.
bitmask display
Not sure about displaying bitmasks in the newer versions of Tunerpro, but I am using ver. 5.0574 of Scannerpro and all you have to do is create "Status" type gauge on the dashboard and then crate a "Bitmask" value to assign to the gauge. Of course you will have to know the packet offset of the value you want to display and the proper bitmask to use.
Charles
Charles
