Ostrich 2
Quattro
Ostrich 2
Post by Quattro »
Hi there people ,
I have both the Rommulator 2 and Ostrich 2 emulators.
The rommulator works on my ECU but the Ostrich doesnt
I can upload and verify the file to the Ostrich but the ECU does not start up .
I noticed that the red stripe on the ostich header goes to pin 1 (a15) but on the rummulator the red stripe goes to Vss (+5v) - pin 28
My ecu is a motronic ECU with 8051 processor and 27C512 (plcc) rom.
I use a adapter from Winslow Adaptics which convers from 28pin dil to 32 pin plcc
*** Note - When scrolling thru the "banks" in tuner pro I did get a bit of movement on the throttle body and fuel pump which tells me that there is some sort off communication.
Any suggestions at all ?
Quattro
Post by Quattro »
bump...
Quattro
Post by Quattro »
Also , when ever i make a change and upload from tunerpro to the emulator (rommulator in this case) the throttle body looses it's calibration .
this makes the car run rich AFR's - possible due to fault code from loss of adaption.
any ideas ?
ecuconnection
Post by ecuconnection »
Did you update checksum?
www.ecuconnections.com DIY tuning forum
