when getting very high load readings .. in my case i suppose it's a base map setting max amm load / rpm .. though where theese settings are located i don't yet know .. .but when passing 0vacuum i get very high load readings.
so i have to lower or possibly raise what load i'm supposed to get..
as when low to part load and 10% throttle will generate +7ms load at 2500rpm .. this is an issue.. but normal highway speeds will generate only 3-4ms in load.. any help adjusting this would be very neat..
as a part solution we'll try to lower the amm factors 25% as we have increased injector and amm to +50%
anyone else that has a good insight into motronic operations ?
will i get lower load readings when lowering amm factors?
Driving Volvo 960 2.8l Twinturbo
proud owner of ostrich 2 and tunerpro RT
