Correct RPM Limit
aboutton
Correct RPM Limit
Post by aboutton »
For all of you using ECU 402-403-405-413 to get correct RPM limit use this equation .
Original raw data is 16bit hex(9065), so you must click ( LSB First ) then the Value will be hex(6590)=26000 this decimal value must be devided over 4 so you will get 26000/4=6500. :D
gavin
Post by gavin »
What do i have to write to Equation Format ? now it is X-30000
aboutton
Post by aboutton »
the equation will be x/4
but make sure to enable ( LSB first ) option[/img]
gavin
Post by gavin »
Great job !!
aboutton
Post by aboutton »
Thanks Gavin.
Any new projects i can help you with ?
gavin
Post by gavin »
Not now,but in future i will need definition for m52b28 engine from Z3,this ECU doesn't have Eprom,so i will need to buy obd2 programer like Galletto or KWP2000.
młody525
Post by młody525 »
Hello
aboutton wrote: but make sure to enable ( LSB first ) option[/img]
Image is not.How to do it?
Thank you.
