Hi...
I am looking for $0E datastream defnition for TunerPro to use with my GMC 3500 1994 7.4L Dually.... I am already using $0D definition, but I feel some of the data are slightly out..
Is there a way to build one if none exists??
Many thanks
$0E datastream definition
Hello -
You can pull down the source definition file here:
ftp://diy-efi.org/pub/gmecm/ALDLstuff.zip
Then find the correct definition (use a text editor), and make the minor correctsion to the 0D file to more accurately reflect the 0E information. I'm guessing you'll find that they're identical, though. Most likely the error you're seeing is simply errors in the definition file.
M
M
