need advise where to start
I have a E36 325i m50b25tu with 413 ecu has all the m54b30 internals.
car is running nicely but under heavy load starts to lean out.
which bin file can i use to start at and which xdf file do use.
please be kind I am still learning and want to understand the tuning side of this thanks
new to tunerpro help 413
Similar situation here, M52B28 with a 413. Car is running VERY RICH with an older Dinan powerdyne supercharger and Dinan software. I bet it's supposed to have one of those Turbotronics magic boxes on the MAF signal wire...
I used TunerPro with the Ostrich on OBD1 Mitsubishi ecus in the past. They had full disassemblies of the code to work with and a plethora of serial port diagnostic tools.
Is there no ALDL style RS232 diagnostic protocol for these Motronic ECU's? This dead-reckoning style of tuning is pretty crude.
Good luck roadrager!
