TPRTv5 crashes when loading log files
JSK333
Post by JSK333 »
I've had this issue for awhile now, every time the app is updated I hope that it will fix my issue, but it never has, even as of the latest 5.00.8606.00.
Once the app is open, I have the EE_Auto.adx (or _Manual) definition loaded, which I downloaded from the main Definitions section on the website. Then I go to Acquisition->Load Log File and choose an .xdl that someone has sent me (I've tried several, all of which work for the people sending them to me). About 1/2 of the way through the loading bar filling up, the app will crash in Windows with the standard "xxx has stopped working" pop-up window and the following data under "problem details":
Problem signature:
Problem Event Name: BEX
Application Name: TunerPro.exe
Application Version: 5.0.8606.0
Application Timestamp: 550b96e8
Fault Module Name: TunerPro.exe
Fault Module Version: 5.0.8606.0
Fault Module Timestamp: 550b96e8
Exception Offset: 00047c7f
Exception Code: c0000409
Exception Data: 00000000
OS Version: 6.1.7601.2.1.0.256.48
Locale ID: 1033
Additional Information 1: 326d
Additional Information 2: 326d02c781672b9c2cc89c850b52fda6
Additional Information 3: 1913
Additional Information 4: 19134b7a1b9655b945ade5a46adf357c
This is on a Windows 7 x64 machine.
Any ideas? I'd really like to be able to play back log files again... it did work in the past, maybe with TPRTv4, but this started somewhere along the line.
-Solomon
