80 Baud Datastream?
80 Baud Datastream?
has anyone ever read a 80 Baud Datastream with TunerPro? is it possible?
stream A046.DS says 80 Baud, i've never seen that before, but someone here has a 81 Cadillac with that Stream and wants to read it ...
that's the same problem I have! (http://forum.tunerpro.net/viewtopic.php ... b63418c7ea)
I think littleno is asking for me here
If someone has a solution please inform us
Unfortunately I haven't seen any information on how to interface with the 80 baud stream.
However, it might just be an exact half of the 160 baud stream. If that is the case, you might be able to create a 160 baud definition and it might work.
Have you tried?
Have you tried?
http://winaldl.joby.se/aldlcable.htm
this is my cable for an other car, do you mean that I should try with this cable and a normal 160 baud definition for my car?
or do you mean something different! sry for my questions^^
I know, he's a perfect guy in this topic, but he doesn't give me an answer when I'm writing him I ask him a lot and yeah how should I say? It's normal that he doesn't want to answer my lots of questions^^
maybe somebody can help me I've time and can wait....
thanks for the hint, and as soon as I've a definition I'll be trying it
I got a ads, but idk if it works, because the transistor of my cable broke down, i took an other one, but it doesn't work in my buick, so I must change the transistor...
but if you can send me the ads file at adikath12@hotmail.com I'd be grateful!
There are no commands for 160 baud. Take a look at the 1227165_160baud.ads file included with TunerPro. Mimic how the ADS header is set up.honken wrote:Do you have a ads for your car now ?
I look at the A46 specs and created a ads for it.
Dont now if its works (cant test it).
Dont now enything aboute the command strings (dident fill it).
But its a start for you if you dont have one.
