I just reviewed the datalog from 4.12 about the data tracing feature, and saw the o2 sensor when hitting a value it went red. Cool, other values did too. How do I set up the parameters? I am using the $OD .ads .
My O2 for instance, if set alarm on will that turn it red, and the value is 1128.32. This is the Alarm high range, times the factor I see. Changing the value < 255 lowers the limit for this alarm? When enabled can I change colors for levels of importance in other alarms?
What was the ALDL data tracing feature added in version 4.12?
color .ads parameters
