I have a 2005 GMC 1500 4.3L, Distributor, DBC, 4L60E Trans and a P59 PCM. I would like to delete the vats.
I can not locate a XDF a file for the PCM.
Can some one point me in the direction of how to make a XDF or maybe if they know what bit turns off the VATS. I would even settle for a software load that has a working XDF I could flash to the PCM.
I have been searching for a solution to this issue for a few days now and just cant seam to find something.
Thanks for looking.. Here is the info from PCM hammer. I can post a bin if you need..
[11:44:01:117] PCM Hammer 021
[11:44:01:126] Monday, June 20 2022 @11:44:01:12
[11:44:01:131] Initializing J2534 Device
[11:44:01:184] Loaded DLL
[11:44:05:543] Connected to the device.
[11:44:05:588] Battery Voltage is: 12.159
[11:44:06:391] Thanks for using PCM Hammer.
[11:44:36:589] VIN: 1GTEC14X45Z166857
[11:44:36:695] OS ID: 12592618
[11:44:36:717] Hardware Type: P01_P59
[11:44:36:795] Calibration ID: 12591721
[11:44:36:860] Hardware ID: 12589161
[11:44:37:068] Serial Number: 0MA030D04278
[11:44:37:128] Broad Cast Code: YHZP
[11:44:37:189] MEC: 0
Sam
2005 GMT-800 P59 PCM VATS Delete
Samuel Rock
Callsign: K5MOB
Trade: Industrial Controls Technician
Hobbies: See Trade
Favorite Quote: The true sign of intelligence is not knowledge but imagination.
Callsign: K5MOB
Hobbies: See Trade
Re: 2005 GMT-800 P59 PCM VATS Delete
I was able to remover the VATS from my PCM using Universal Patcher..
Samuel Rock
Callsign: K5MOB
Hobbies: See Trade
Callsign: K5MOB
Hobbies: See Trade
