153 Bosch pops on throttle release
Posted: Thu Jul 13, 2023 2:41 pm
by Adhamkhe
Hi usually theres no problems with the issue of pops but theres a car thats not working well with this. The pops are only happening when slight throttle is applied. The ignition timing low load is set to -13.96( 0 no conversion ) at low load first colomn from 1500 to 6500. And idle ignition timing is set to same value at the last 3 values .
Usually this works great. But not on this car
The engine is m20b25 turbo stock internals
Everything is great except the pops
I was thinking about opening the throttle a bit mechanically if theres no solution to be found here
Ill supply the bin file if needed
Thanks in advance
