This Program Does not support the Version of Windows your Computer is running....
Windows XP SP3
running in a virtualbox vm
Tuning an old ecm and pretty much all the software runs best on an XP box.
SetupTunerProFree_v500_8369 - This Program does not support.
I downloaded this patch, running XP SP2, and it installed fine. Have a registered version of TPRT, no problems. Now, when I try to open TunerPro RT, instead of opening the program, I get an error that says:
"The procedure entry point GetLocicalProcessorInformation could not be located in the dynamic link library KERNEL32.dll"
Tried going to the icon in the start menu and finding it manually, figuring one might be pointing to the wrong program, but no luck. Is there a trick to installing the program other than double clicking the setup executable?
