color .ads parameters
Psychedelic speed
Post by Psychedelic speed »
I just reviewed the datalog from 4.12 about the data tracing feature, and saw the o2 sensor when hitting a value it went red. Cool, other values did too. How do I set up the parameters? I am using the $OD .ads .
My O2 for instance, if set alarm on will that turn it red, and the value is 1128.32. This is the Alarm high range, times the factor I see. Changing the value < 255 lowers the limit for this alarm? When enabled can I change colors for levels of importance in other alarms?
What was the ALDL data tracing feature added in version 4.12?
JP86SS
Post by JP86SS »
You can link the ADS item to your XDF and watch the cursor move while you emulate and datalog at the same time.
Must use floating point or integer values that match the ads ranges.
Alarms cause the color you see. High alarm is red, low is orange. Values higher than the high threshold and lower than the low threshold cause alarm.
