Hi All!
I did try searching but the results did not narrow it down to an answer.
I'm an independent shop owner. In my spare time I help people with "projects". Currently I'm working on a 1985 El Camino 305 for a neighbor's young son. After all the tune up and adjustment procedures I'd like to view data to make sure all the sensors are responding and that the parameters are within limits.
I've done a little research and it seems that TunerPro and a "Moates cable" will do the trick. Honestly I'm not trying to tune or change parameters. I'm not trying to be cheap either. I just want to plug something into my laptop, check some numbers and make sure I've done good work.
Can it be this simple? If so, can any of you guide me? I'd certainly appreciate it.
Thanks in advance! -Kerry
85 305 El Camino data reading
