Table Trace Query
Table Trace Query
I am trying to implement table tracing on a table where the row axis is MAP but it uses only about 40% of the MAP range. The row input value is the 2 bar sensor raw MAP A-D counts scaled to a range of 0.3 - 1.9 bar and then this is clipped to 1.21 - 1.9 bar by subtracting 0x90 from the value. Does any one know how to set up either the .xdf or .adx to allow tracing in such an instance as this?
My initial thought was to set up a 'dummy' map value in the .adx and assign the table's row DA association to it. I've tried it with the equation:
(X-144)/128+0.08
but this doesn't work (please note I am deliberately ignoring the scaling of the raw A-D count to the 0.3 - 1.9 bar value here to simplify things at this stage).
Thanks.
(X-144)/128+0.08
Thanks.
- Six_Shooter
This is for a Ford application, I would assume?
Are you using data hit tracing or datastream from a Quarterhorse?
I know on the GM stuff, TP just uses the value in the variable that is displayed from the ADX and matches it up to the value in the axis of the table, regardless of using the whole scale or not. Have you tried just straight linking the full scale ADX variable to the table?
For data tracing the .xdf and .adx files have to be in the same file.
Don't know if this will help but it's from the help section of TPV5
TunerPro RT implements a feature that allows you to correlate data acquisition data with bin parameters in real-time. This feature is useful for quickly identifying problem areas in a tune and the parameters responsible for the problem. This is accomplished by "linking" an XDF (bin definition) file with an ADX (Acquisition Datastream definition) file. Once the link has been made, you can edit the XDF items to have direct links to ADX items.
Some notes on data acquisition data tracing:
XDF Constants with ADX linkage will display the ALDL output in the opened constant editor (see Figure A below)
XDF Tables with ADX linkage will show the currently active cells in a highlighted state (see Figure B below)
In order for XDF Tables to be linked, the axes output types must be set to a non-string type (i.e. int, float, etc). If set to string, TunerPro cannot resolve Data Acquisition output to an axis value.
When using explicit linking, the link path between an XDF and ADX is relative. If distributing linked files, it is simplest to link the files while they are in the same directory (and distribute them that way). If the ADX and XDF files live in different directories, the files must be distributed (i.e. zipped or rared) with the directory structure intact.
yes same folder... sorry...
can you email me your bin, xdf and adx file? I've got some time to kill today and will give it a shot as I am in this stage of learning curve with the software as well?
eaglemarkyoung@gmail.com
EDIT: It may be helpful if I had your xdl log file too.
- Six_Shooter
darn Fords! ![Very Happy :D](./images/smilies/icon_biggrin.gif)
- Six_Shooter
- Six_Shooter
You thinking about nitrous?Six_Shooter wrote:Hmmm.
That the secondary injector would work perfect for an idea that a friend of mine and I had, that would require secondary injectors to shut off, due to using progressive throttle linkage.
Are the code and related files uploaded somewhere? I'd love to see how well this would work for that idea.
- Six_Shooter
