Feat. Direction of linked Table configureable
rob
Post by rob »
I have another Feature suggestion.
I have seperate Maps for RPM and MAP Bins (because in the Summary List - F7, i can see which addresses are occupied and which are free), in the Injection Map i link these Maps via Scale/Normalizer Link which works fine. If i change a conversion factor i have to change it only once. BUT i can't change the order of the variables (ascending or descending). Everywhere else i can use Address Step 2 for 16bit ascending or -2 for 16bit descending.
Also directly at the source, in the Maps from the bins, i can't change the order.
This would be really nice if this would be possible.
darkcorp
Re: Feat. Direction of linked Table configureable
Post by darkcorp »
Don't want to start a new thread.
Question regarding linking the data of similar tables for example O2 goal for left and right banks.
I use THAT(id; row; col; precalc) function but it requires entering the corresponding formula into each individual conversation cell of the table.
Is there an easier way to link two tables? Maybe by usage of indexing?
JEEP 4.6 stroker, JTEC tuner
This should have been a new topic, as it's only very loosely related to the previous post.
This should work with a global equation. If you're willing, create a definition with the tables to repro this and send me the XDF and bin and I will look into it.
darkcorp
Post by darkcorp »
Mangus wrote: Tue Jan 27, 2026 9:12 am This should work with a global equation.
Solved by
Code: Select all
THAT(29414; ROW(); COL(); FALSE)
