I am trying to add a vacuum gauge (in-Hg) in the my adx, Im not too sure on the formula, could some help me out please?
I am using a MPX5700AP pressure sensor. Ive got a boost and MAP gauge working fine.
Boost gauge (PSI) formula ((((X/255) - 0.04)/0.0012858)*0.145) - 14.530
MAP gauge formula (((X/255) - 0.04)/0.0012858)
I think its (((((X/255) - 0.04)/0.0012858)*0.145) - 14.530)*-2.036025
Is that correct?
thanks
Vacuum Gauge in tuner pro
I have been trying to figure out the same thing. My answer from another website and user VL400:
You can link directly to other items when configuring the ADX which makes the equations simpler and its worth using the baro item to get a true vacuum reading. Baro (or barometric pressure) is the MAP sensor reading at key on and engine off, its also updated during running under certain conditions.
Add a new item and the equation can be (X - Y) * 0.2952999 to display inches of mercury
X = linked to Baro
Y = linked to MAP
kPa to inHg is 0.2952999.
X = linked to Baro
Y = linked to MAP
