Newbie using Tunerpro; versions?
krav84
Post by krav84 »
Whats the difference between tuner pro and tunerpro RT? is it actual software differences or just paid version has free/faster support?
I just used pcmhammer to read entire pcm and save stock bin.
then used tunerpro with the 2156 XDF to modify that Bin, delete vats, enable electric fans and delete Dtc codes.
It saved as new modified bin, but at time of saving it gave me a warning error code saying;
Error-one or more checksums could not be updated. check checksum adresses etc, for validity
Im told i shouldnt write this to my PCM until this is fixed.
whats goin on here?
jimmy1984
Re: Newbie using Tunerpro; versions?
Post by jimmy1984 »
Im having the same problem did you ever get it fixed ?
Richard03
Post by Richard03 »
As far as I know, TunerPro RT isn’t just about support—it adds real-time data logging and emulation features, while standard TunerPro is mainly for offline editing. The checksum warning usually means the XDF doesn’t define all required checksum routines for that PCM.
