I'm using TunerPro RT build 5.00.7774.00 with an AutoProm from Moates on a '94 Chevy C1500 with 7427 ECU.
When I attempt to upload the current BIN to the emulator, TunerPro RT crashes. The BIN I have open is a read from a Jet chip and the file size is 32kb. I read the chip using the Moates APU1 unit. I am using the 0D_TPV5_v250.xdf file and the A217_0D_v250.adx definition file, both downloaded from tunerpro.net.
After reading some of the other posts, I figured I needed to change the BIN file size in the XDF header section. Since the BIN file is 32768 bytes on disk, I set the BIN size in the XDF to 8000 (hex). No luck.
I tried to upload the BIN using TunerPro 4, it doesn't crash and the verification is successful; however, I cannot figure out a way to configure the COM port setting in TunerPro to be anything other than COM1 (the AutoProm is COM4) so I am unable to do DataLogging.
Another item worth mentioning...
During my troubleshooting with TunerPro v5, if I do not select an XDF file, I can upload the BIN to the emulator without it crashing and the verification works as well. Then, I select the XDF I want to use and the verification still works as intended. If I try to upload it states successful, but then the verification fails again. Honestly, I think this is bypassing something and not necessarily making it actually work.
Any assistance would be great. I can provide the BIN file and other information as needed.
thanks,
TunerPro RT 5 Crashes when Uploading BIN to Emulator
Mark, Those files come from that same Zip package we had very strange issue with for the 220_transv250.adx
http://tunerpro.net/forum/viewtopic.php?t=2618
Tomgilb if you want to try another xdf I have one that I know works in this thread.
http://www.gearhead-efi.com/Fuel-Inject ... rmation-OD
I received the bin and XDF, and am unable to reproduce a crash using the latest build of V5 on the website. Are there any special steps that I would need to take?
I started V5 with the AutoProm attached, loaded the bin, loaded the XDF, and hit the upload button (up arrow) on the toolbar.
