the connection says is successful but the data is flashing all over place. Ignition voltage rmp etc basically everything flashing and even the ECM software version and engine type is not recording properly ?
Any suggestions
i am using MEFIBURN with scanerpro (some reason tunerproRT is not scanning even though ports set up same as scanner pro which is basically same software)
using MEFI4.adx defenition
Data jumping all over place, what is wrong
there are 3 mode1 commands as follows:
Mode 1 message 0 ALDL request
Reply - Mode 1 Message 0 ALDL Request
Macro - Mode 1 Message 0 ALDL Request
Mode 1 Message 2 ALDL Request
Reply - Mode 1 Message 2 ALDL Request
Macro - Mode 1 Message 2 ALDL Request
Mode 1 Message 4 ALDL Request
Reply - Mode 1 Message 4 ALDL Request
Macro - Mode 1 Message 4 ALDL Request
Do i change them all by 1 ?
thanks
thanks
If changing the Mode commands does not work, try this.
With the MEFIBurn USB cable unplugged open Windows Device Manager (Under control Panel, System) and click on the “+” next to Ports (COM& LPT).
You will probably see a printer and Serial port (depending on your computer’s hardware and perhaps some other USB devices.
Plug in the MEFIBurn USB cable. There should be another USB device added to the list of Ports, mine is labeled “USB Serial Port (Com 4)”. Double click on the new port and then the “Settings” tab.
My port settings are:
bits per sec = 9600
data bits = 8
parity = None
Stop Bits = 1
Flow Control = None
Open ScannerPro and look under File, Preferences and make sure that the Com port is the same as set in Device Manager.
My ScannerPro will sometimes not connect correctly, but hitting the connect/disconnect button usually fixes the problem.
If it still does not work, try uninstalling and then reinstalling the driver.
Are you using Windows XP, Vista, 7?
Charles
bits per sec = 9600
data bits = 8
parity = None
Stop Bits = 1
Flow Control = None
Charles
Hi Charles,
have updated thread in new thread here :
http://forum.tunerpro.net/viewtopic.php?t=2896
seems tunerproRT v5 does not work with mefi4.adx files for scanning, or at least i cant get mine to connect even though ports are set correctly.
i am using scannerpro please see my new thread re this.
Sorry for the confusion !!!
am using windows 7 64BIT
