Is 4 ALDL Monitors the max you can have displayed ?
KrazyKaycee
Post by KrazyKaycee »
Question says it all :). If it can display more than 4 what do you do to add a 5th?
Any input welcome :)
Kaycee
honken
Post by honken »
If you men scannerpro you ad it in ADX editor.
http://forum.tunerpro.net/viewtopic.php?t=518
Post by Six_Shooter »
honken wrote:If you men scannerpro you ad it in ADX editor.
Tuner Pro RT has an ALDL dash, values, monitors etc.
I don't know if there is anyway at this time to add more monitors, there is no way to add more guages, Mark has already confirmed that, so I would imagine the monitors to be the same.
Once Scanner Pro is through beta testing and integrated with Tuner Pro, you will be able to add as many guages and monitors as you deem good.
KrazyKaycee
Well that works for me :). Thanks all
Is scanner pro in a closed beta test atm ?
Krazykaycee
