Datalogging Question
Rally Smith
Post by Rally Smith »
I have Tuner Pro RT V5 and trying to Data Log my Camaro. It will not connect the ALDL. Any help would be appreciated. I am using the ALDL Cable from here. http://www.aldlcable.com/
Thanks in advance.
Post by robertisaar »
what year and motor didit come with from the factory? and has the ECM been swapped out since then?
Rally Smith
Sorry, I didn't put that in to begin with.
1991 Camaro RS, 305 TBI, Automatic, Stock Computer setup.
RS
V5 has been having issues with the 160 baud stuff...
but try setting the port speed to 4800 baud (IIRC for a USB, and 2400 for serial), then using the 10K resistor, you should be able to connect. i'm not aware of what mask this is, or even if a public datastream is out there, but worst case scenario, V4 will likely work with a proper ADS.
Rally Smith
I will give that a shot.
Thanks Robert
You don't need the 10K resistor, and I have yet to reproduce any 160 baud issues.
i'll rephrase: people have been having issues with V5 and 160baud...
and i assumed the 10K was used for all 160baud streams.... a lot of the source files indicate they do, i guess GM could have changed a few things around.
robertisaar wrote:i'll rephrase: people have been having issues with V5 and 160baud...
I understood the original statement. Problem is, I can repro no issues on any of my machines.
10K resistor is necessary only for 1227165 and the '85 TPI ECMs.
