Trouble Data Logging 165 with a usb cable from ALDLcable.com
mcagauto
Post by mcagauto »
Hi I am having trouble with my cable i bought from aldlcable.com i cant make it work with any data logging program I have a tpi set up of of a 86 chevy that is put in a 77 chevy truck with a 400 engine and the 165 ecm. I have programed the chip using AUJL to start with. My snap on scanner shows everythang is good no codes but I cant make it data log. Im using a modifide AUJL bin and a 6e xdf and a 6e ads. Im sure it is somthing small that i am missing any help would be great thanks Michael :P
Are you setting the proper COM port to use with your USB cable? Most likely the cable installs a virtual COM port, and that COM port number must be properly set in your logging software.
