RPM scalar
Posted: Wed Dec 16, 2009 5:02 am
by tom
whoever knows what I can change RPM scalar? Stock maps end 6400RPM so I must rise axis this map above 7300RPM but how?? I`ve done similar it in Digifant, its`easy on this type ECU
Posted: Wed Dec 16, 2009 4:08 pm
by revlimit
You can expand maps, increase the load and rpm scale in any Motronic ecu. But it is confusing because you got to calculate backwards, On all motronics, RPM and LOAD scalers are located before the maps, so you will have to add those in the XDF and tune from there. But most tuners do not touch this because the time you will spend past 6000 rpm is so short that there is no real point of expanding it. Ecu will just use the last known value when going high rpm than that.
Posted: Wed Dec 16, 2009 4:40 pm
by tom
I would like try change it because now I`ve very hard camshaft, so max power it`s above end RPM on the map. If you can help me with this I will be glad
Posted: Wed Jan 27, 2010 9:59 am
by zav3n
so if i absolutly had to expand the maps to 7k i would have to edit the .xds file and add 7000 to all the lines/maps ect that i wanted to expand, for example from the 413.xds
040360 YLabels =680,880,1120,1320,1600,2000,2200,2480,2920,3280,3640,4000,4600,5320,6080,6400,7000
i add accordingly?
or can i just try to create a .ECU and raise it from the get go?
revlimit wrote:You can expand maps, increase the load and rpm scale in any Motronic ecu. But it is confusing because you got to calculate backwards, On all motronics, RPM and LOAD scalers are located before the maps, so you will have to add those in the XDF and tune from there. But most tuners do not touch this because the time you will spend past 6000 rpm is so short that there is no real point of expanding it. Ecu will just use the last known value when going high rpm than that.
Posted: Wed Jan 27, 2010 10:54 am
by revlimit
zav3n wrote:so if i absolutly had to expand the maps to 7k i would have to edit the .xds file and add 7000 to all the lines/maps ect that i wanted to expand, for example from the 413.xds
i add accordingly?
LOL!!! What the heck are you talking about?
Posted: Wed Jan 27, 2010 11:10 am
by zav3n
im talking about creating a .ecu file:
http://tunerpro.net/tutorials/CreatingECUs.htm
i think i figured it out.....
Posted: Wed Jan 27, 2010 11:44 am
by ecuconnection
i add accordingly?
Yikes!!
Posted: Wed Jan 27, 2010 4:02 pm
by revlimit
zav3n wrote:im talking about creating a .ecu file:
That is old. Now we use XDF files. And now you can't expand motronic maps, that way.
Posted: Wed Jan 27, 2010 4:20 pm
by zav3n
ya i saw that.. im using the redlabel 413.xdf, do you know how to edit the xdf file becuase when you open it, it says clearly on the first line do not edit by hand...
Posted: Wed Jan 27, 2010 5:35 pm
by revlimit
you load it into tunerpro and you edit it there. Play with the tunerpro software you will figure it out
Posted: Thu Jan 28, 2010 9:50 am
by zav3n
thx i figured it out but didnt even bother extending it cuz really and truly ur right after 6400-7000 the time is so little even in high gears it never knocks/pings at all. ;-)
Posted: Wed Aug 25, 2010 11:36 am
by revlimit
New version of Tunerpro 5 has a feature to adjust RPM and LOAD scales, and displayes them correctly. What needs to be done is all XDFs in the download section will need rework.
