properly Calculating connect macro checksum
Sil
Post by Sil »
hi, i have df, and need the calculate the checksum for the connect command, how do i go about doing that to get the checksum to add to the end
Depends on the vehicle. In the latest builds, TunerPro will calculate this for you, provided your vehicle uses one of the built-in calculations.
i just used the checksum that TPV4(or V5, i'm not really sure which did it) calculated when i imported the ADS... though i'm not sure of which of the options GM ECMs do...
GM OBDI vehicle command checksum is 1's compliment of the preceding bytes.
-M
really? because if i set to 1's compliment i get a checksum value exactly 1 below what the previous checksum was calculated as after i remove it, while 2's compliment gives me the same number as the checksum that i removed...
robertisaar wrote:really? because if i set to 1's compliment i get a checksum value exactly 1 below what the previous checksum was calculated as after i remove it, while 2's compliment gives me the same number as the checksum that i removed...
You are correct; 2's compliment. Sorry for the missed key.
