V500.5150.00+
V500.5150.00+
Post by Six_Shooter »
Is it just me or is there no "Disable Checksum While Uploading" option on build 5150 or above?
I hadn't noticed this until today, since today is the first time this year back into tuning (and a friend's car I might add, mine is still in pieces :( ).
Has it been moved elsewhere (I have looked wasn't able to find it) or just completly removed from the program and need to edit the bin manually in the hex editor?
I removed it. It caused more trouble than it was worth. You should manually disable the checksum where possible (generally by setting the mask ID byte to 0xAA for GM vehicles).
Ok, all I need to know. Thanks Mark.
