Firebird 1995 manual LT1, Tuner Pro RT V5, ALDU1 and CABL2
psykopat13
Post by psykopat13 »
I'm able to datalog with DataMaster (so the cable is OK), but not with Tuner Pro RT V5, No hardware found. Test cable OK but when I plug on the car It doesn't work. File .adx EE manual download from Tunerpro.net. OS is windows Vista. Please Help !!!
no hardware found is a normal message when using an ALDL cable. the hardware message mainly relates to burning or emulating hardware.
psykopat13
Why i'm not able to data log?
passing the built-in test should indicate that you can.... i would confirm you have the correct port set, as with vista and 7 for some reason an extra fake serial port has been created on my laptop and will pass the test every time.
psykopat13
Com 3 validate with control panel. As I say It work with DataMaster. The error message is something like unable to communicate at 8192 Baud rate
psykopat13
Anybody have a idea ????
Is it a bug with the 95 LT1 OBD1. Did I miss something ? Nobody can help ?
akeemo
Post by akeemo »
change the baud rate to 4800... maybe data is flowing faster than one of the particular pieces of hardware can read.that will be in the device manager of PC.. or the preferences of the software.
Hope this helps..
Noel
