TunerproRT quits reading data during scans
What would cause the Tunerpro RT to quit reading data during a scan? Sometimes I can go on a 20 minute drive and scan. Other times it will quit reading data every 2 minutes. Which means I have to shut the car off and start over. The other day when I was trying to scan, it quit reading data 5 times.
The laptop sits still while I'm driving. So, I wouldn't think of it being a connection coming loose. But maybe I could try on my next scan to wiggle the connections on my cable to see if maybe that is the problem. I have a Moates cable.
It's an 89 Corvette. I looked around and came up with the number you posted: 1227165.robertisaar wrote:what ECM and/or mask? i know the 1227165 is notorious for doing stuff like this. whether it's a GM code bug or a hardware issue, no one knows for sure.
So, I'm assuming it has something to do with this particular ECM? And not the cable/laptop/software?
It does make it hard to do a scan if you have to sometimes stop every 2 miles and restart the car and restart the scan. I wonder if I'd have the same problem if I used an AutoXray?
Though, after I get connected. I turn the 10k resistor off. I don't know if that would have anything to do with it?
I run the '165 ECM in my car and this is something that most likely you will have to just deal with. I don't seem to have as much trouble with it cutting out with v5 as I did with v4 but it is the ECM, not the cable or TunerPro.
I have swapped ECM's, left the 10k on, changed ALDL harnesses and anything else I could think of and the bottom line is the '165 ECM will stop sending the data stream signal at any time for no apparent reason.
Good Luck,
Dewayne
Good Luck,
Dewayne
1989 Camaro Rs, 383 HSR, 280/288 XFI roller cam, T-5, 3.73 gears, 130 shot
I've got V4. Looks like I need to replace it with V5 and see how that goes.DSmith1989 wrote:I run the '165 ECM in my car and this is something that most likely you will have to just deal with. I don't seem to have as much trouble with it cutting out with v5 as I did with v4 but it is the ECM, not the cable or TunerPro.
Good Luck,
Dewayne
Do you have to restart your car everytime it quits reading data? I shut down and restart the TunerProRT. But can't get it to reconnect with the car already running. It has to be with the key "on".
Is it possible it could be a bad cable? I've got a Moates cable.
I went ahead and cleaned the ECM and plug contacts with contact cleaner. And also sprayed the ALDL. And I cleaned all the engine grounds. I had it idling and it quit flowing data after around 10 minutes.
I had also read of this problem with Datamaster. And they said for Datamaster that you can adjust the speed of the connection so some laptops can communicate at a rate that the ECM can keep up with.
I was looking into doing some scans and sending them off so I could burn chips and tune my car. Which requires 20+ datalogs under certain driving conditions. And I'm betting I'm going to have a problem getting those datalogs.
check that your laptop does not have any kind of motion sensing protection built in. For example I have an IBM thinkpad that I use for logging. It has a feature called "Active Protection". There must be some kind of motion sensor in it and whenever it senses that there is too much movement it parks the hard drive and stops TP from writing to the log file.
Just another thing to check.
I don't believe it has that. Could it be the cable? Its a Moates cable.cmaje72 wrote:check that your laptop does not have any kind of motion sensing protection built in. For example I have an IBM thinkpad that I use for logging. It has a feature called "Active Protection". There must be some kind of motion sensor in it and whenever it senses that there is too much movement it parks the hard drive and stops TP from writing to the log file.
I think he told you it's not the cable...DSmith1989 wrote:I run the '165 ECM in my car and this is something that most likely you will have to just deal with. I don't seem to have as much trouble with it cutting out with v5 as I did with v4 but it is the ECM, not the cable or TunerPro.
Good Luck,
Dewayne
There's other guys who had similar problems and it was the cable. Which is why I thought it might be the cable.EagleMark wrote:I think he told you it's not the cable...DSmith1989 wrote:I run the '165 ECM in my car and this is something that most likely you will have to just deal with. I don't seem to have as much trouble with it cutting out with v5 as I did with v4 but it is the ECM, not the cable or TunerPro.
Good Luck,
Dewayne
But I have read on here about the 165 ECM. But there are alot of guys with that computer who don't have any problems at all.
I hate when that happens!
I am having a simalar issue with a LT1 ADX. Not stopping, just glitching from correct looking data to? and back... some guys say it works fine, others say not at all, I am in the middle?
Since I run everything through a USB AutoProm, set switches as pass through is the only differance. Works on all other ECMs. But I ordered a cable to try as well...
Good luck!
Good luck!
