Bmw M50B25 Turbo bin...
Posted: Fri Aug 26, 2011 10:21 pm
by 95932148
Hello.. I need a Bin file for my bmw..I have a M50B25 engine with turbo. I drive with a boost pressure around 21 PSI..
Sorry for my crappy english..
Posted: Sat Aug 27, 2011 9:02 am
by DmcL
doubt anyone will be able to magically create a tune for u.. too many variables. u will need to tune it yourself or get someone else to tune it.
Posted: Sat Aug 27, 2011 6:09 pm
by revlimit
PM me I will send you one
M50b25 turbo bin
Posted: Fri Mar 30, 2012 5:56 am
by tunisianpower
Can I get a copy to test with my bin?
thank you
Amine /tunisia
Posted: Sun Apr 01, 2012 9:03 am
by aboutton
what modifications you did ?
hello
Posted: Sun Apr 01, 2012 10:20 am
by tunisianpower
hello
j'ai mis un turbo KKK K29 , des injecteurs 350cc , ITB s50b30 euro , dump valve HKS , wasteqate greddy , boost control, ma pression sera a 0.8 max 1 bar (14/ 16 psi) ligne d'échappement inox libre diametre 90 , bobine S54 m3e46 , bougies froide , regulateur de pression d'essence reglable , double pompe bosch 044 , ressort soupape eibach , rapport volumetrique 8.6.1 ( joint de culasse comectic 3.5 mm ) , boite de m3 e36 , pont LSD 4.27 , .......
Posted: Mon Apr 02, 2012 5:30 am
by aboutton
La boite vitesse est Getrag 5 vitesse 1ere en bas ?
le pont LSD 4.27 doit estre le plus long possible ca veux dire 3.15 out 3.07 sera plus mieux.
Posted: Mon Apr 02, 2012 8:24 am
by tunisianpower
pour le pont : c une caisse de circuit , elle est configurée pour le drift , et la boite c une ZF (5eme prise directe) rapport final : 1
