Correct RPM Limit
Posted: Wed Oct 26, 2011 5:44 am
by aboutton
For all of you using ECU 402-403-405-413 to get correct RPM limit use this equation .
Original raw data is 16bit hex(9065), so you must click ( LSB First ) then the Value will be hex(6590)=26000 this decimal value must be devided over 4 so you will get 26000/4=6500. :D
Posted: Wed Oct 26, 2011 8:00 am
by gavin
What do i have to write to Equation Format ? now it is X-30000
Posted: Wed Oct 26, 2011 11:52 am
by aboutton
the equation will be x/4
but make sure to enable ( LSB first ) option[/img]
Posted: Thu Oct 27, 2011 7:22 am
by gavin
Great job !!
Posted: Fri Oct 28, 2011 10:15 am
by aboutton
Thanks Gavin.
Any new projects i can help you with ?
Posted: Mon Oct 31, 2011 2:34 am
by gavin
Not now,but in future i will need definition for m52b28 engine from Z3,this ECU doesn't have Eprom,so i will need to buy obd2 programer like Galletto or KWP2000.
Posted: Fri Jul 15, 2016 11:23 am
by młody525
Hello
aboutton wrote: but make sure to enable ( LSB first ) option[/img]
Image is not.How to do it?
Thank you.
