Ive been looking into tuning the ecu in my barina for some time now.
They do it all over the UK however in Australia there are very limited options, almost non existant to tuning options.
Heres where I am at currently:
Managed to interface with the ecu and pull the bin file off it. Identified 42 potential maps in winols, now to start picking away at the useless data to find the actual maps I need. (any guidence on this would be fantastic, always keen to learn)
Here is where it gets interesting.
While using an OBD2 scan tool (to find out if my o2 sensor has had it, it has
i came across some readings under the ecu data headding.
It says:
OBD compatability: OBD1
$11
Im curious if that means the car is actually OBD1 not OBD2 as I originally thought and it has a Mask id of $11.
I know the Mask Id $11 is common with our holden commodores so is it possible there may already be an XDF out there compatable with my car?, and is it possible to have a car that is OBD1 with an OBD2 connector??
Damn euro cars being so different and difficult.
The car is a Holden XC barina SRI 2001 with the Z18XE engine which i believe is run by the Siemens Simtec 71 ecu. Also known as the Corsa C sri overseas and has the same running gear as the Astra G and H.
Any help is greatly appreciated, And its nice to finally be a part of the forums
Kind Regards
Rick
