Can a "Value" item's trace be inverted
kojab
Post by kojab »
First Post.
Thanks to Mark and anyone else involved in making this powerful tuning and diagnostic tool available.
I would like to invert my WideBand A/F trace as I am so used to seeing rich as up and lean as down. I think it a age problem I have.
I hope it's possible. Just cannot find a way to do it. TIA
Cheers
Dick
You can reverse rows/columns in preferences or by right-clicking in the table.
kojab
Post by kojab »
Sorry I did not make my post clear. Very new to TunerPro.
The WideBand trace is one of my logged items in my ADX.
Range Low = 9
Range High = 18
Conversion for WB = 17.97 - (x*0.031914062)
Wideband is working fine, just that for me it's displayed upside down.
by trace, i assume this is in a monitor view....
i can see a few solutions, some working better than others. changing the min/max range, along with the equation to display negative numbers would do such a thing and leave good data, just with the wrong sign in front of it.
creating an AFR "error" value, dividing target AFR with read AFR(commanded 13:1 and reading 12:1, 13/12=1.083), min/max could be something like a .5 to 1.5 range.
Robert is correct and thinking along good lines. There is much opportunity for me to make this easier, though. Note taken.
kojab
Post by kojab »
Thank you Robert and Mark for your thoughts. I will have a play with the settings and see if I can get it to work.
I would like to register my TunerPro 5. Can I use the one registration for several personal computers/laptops ?
Post by Six_Shooter »
Yes. One registration file works on as many computers as you own. This is good for when a computer needs to be replaced. I also register my copy on my PC so that when I'm reviewing logs and bins on my desktop it makes it gets rid of that nag screen. ;)
