ALDL/Data Stream Input Question
desmo01
Post by desmo01 »
Yo Mangus! Will TunerPro take an RS232 data stream defined as follows?
Data Frame Format
1 - Frame Header byte 1 (0x5A)
2 - Frame Header byte 2 (0xA5)
3 - Frame Sequence counter
4 - SVout ADC high
5 - SVout ADC low
6 - User 1 ADC high byte
7 - User 1 ADC low byte
8 - User 2 ADC high byte
9 - User 2 ADC low byte
10 - RPM count high byte
11 - RPM count low bye
12 - CRC (1's comp. sum of above)
or:
2.0 Data Frame Format
4 - Tick high byte (1 tick = 1/100 Second)
5 - Tick low byte
6 - Wideband ADC high byte
7 - Wideband ADC low byte
8 - Ipx high byte (8192=F/A, 4096=stoich)
9 - Ipx low byte
10 - User 1 ADC high byte (V1 input)
11 - User 1 ADC low byte
12 - User 2 ADC high byte (V2 input)
13 - User 2 ADC low byte
14 - User 3 ADC high byte (V3 input)
15 - User 3 ADC low byte
16 - Thermocouple 1 ADC high (T1 Input)
17 - Thermocouple 1 ADC low
18 - Thermocouple 2 ADC high (T2 Input)
19 - Thermocouple 2 ADC low
20 - Thermocouple 3 ADC high (T3 Input)
21 - Thermocouple 3 ADC low
22 - Thermistor ADC high (internal sensor)
23 - Thermistor ADC low
24 - RPM count high byte
25 - RPM count low bye
26 - Status/Error high byte
27 - Status/Error low byte
28 - CRC (1's comp. sum of above)
More info on:
http://www.wbo2.com/2a0/logger.htm#serialframes
Getting this thing to read into TP-RT would be very good. How similar is the ALDL stream to RS232? Would it be possible to get it to read in via an RS232 (or USB port via RS232 convertor) while emulating with Ostrich?
Hope you're doing good!
Best Regards,
desmo01
