logging problem
Jens.j
logging problem
Post by Jens.j »
Hi, i can not get steady data when i am logging.I am using a cable from aldlcable.com. (12pin to USB) When the engine is at idle the RPM jump betwen 0 to 6000 and the TPS is betven 0 and 4000%. I am using TunerProRT and the car is a caprice 91.I have also tried Winaldl and i cant get steady data there ither. Is it the cable?
It could either be a bad cable or the wrong definition being used to analyze the data from the vehicle. What ADS file are you using for TunerPro?
Jens.j
Post by Jens.j »
It is a ADS file i found at moates for 16136965, I have also got a new cable from moates that i will try this weekend.
Jens.j
Post by Jens.j »
The data is more stabile with the new cable but it still jumps around at times. I have a MSD 6AL inside the car that might interfer with the data transmission. The ADS is probobly bad aswell since the TPS % is still between 800 and 1500% and MPH and KPH dont add up
Jens.j wrote:The data is more stabile with the new cable but it still jumps around at times. I have a MSD 6AL inside the car that might interfer with the data transmission. The ADS is probobly bad aswell since the TPS % is still between 800 and 1500% and MPH and KPH dont add up
You can edit the ADS.
