ROYAL ENFIELD KEIHIN (2016) ECM TUNING
Posted: Sun May 04, 2025 9:24 pm
by thefastelephant
Am new to the forum and need help in tuning my stock ECU for the motorcycle. Details are :
Make: Royal Enfield
Model: Continental GT 535cc ( 2016 )
Engine Type : Single Cylinder
Am looking at any leads on being able to tune the stock ECU as there is nothing available online for tuning the stock ECU.
Additionally, I also want to know how can one do the same.
Model of the ECU : 630p-1992-000
Attaching photos for reference.
It has 2 rows of pins on the ECU and uses K-Line protocol.
Re: ROYAL ENFIELD KEIHIN (2016) ECM TUNING
Posted: Wed Jun 04, 2025 9:59 pm
by genuine
This 535 series is from Keihin – Made in Japan – so the ability to open the code or dump the firmware will be more difficult than Bosch or Delphi. But not impossible. If you have a device like tactrix openport 2.0 and software using K-Line (you can try TunerPro + XDF separately if someone can build it), then you can at least read the bin file and find the map point. I used to work with Honda CRF also using Keihin, quite similar.
