Tune Questions
derrin
Tune Questions
Post by derrin »
Well to start i am new to this program and hardwear. However i have been tuning using other systems.
I am tuning a customers 91 syclone today and need to make sure somethings are right. the pcm is 7749 i have the moates setup working
datalogging read/burn chips. 58rr_v14*xdf
1.
The customer has 55 lb injectors were to i check to make sure this program knows that?
2. customer had several chips i read them all. Started to adjust the one were the car ran the best, first thing that i notice is on the tunes i don't want the a/f tarket is 14.7. on the tune i want is stays at 10
why is this?
3. What turns on premium fuel?
4. is there a problem making more boost pressure than desired?
well hows that for a start?
looking at more info now.
thanks for your help.
derrin
Post by derrin »
Was this post suppose to be under gm tuning?
ok i can answer some of my own questions.
The customer has 50 lb injectors not 55 tune i am using i know is set for stock were do i adjust for them?
the tune i am using also is for a 2 bar map and the car has a 3bar
were are those changes made
Boost is not cpu controlled, ext. wategate
isn't there a place on the web that expains this i hope so i hate feeling like this, using to much of peoples time.
A guy just called me from mexico and wants me to tell him his compresson over the phone while he cranks on the car.
i degress
:lol:
Post by Six_Shooter »
What bin file are you using?
You may be better off starting with $59 than $58, due to the fact that you have a 3 BAR MAP sensor already.
It is freeware, but the creators of the code $59 have some specific requirments when it comes to tuners that charge for thier services.
derrin
Post by derrin »
i really don't know the exact answer.
the bin file that i am adjusting i read off of one of the customers "stock" chips. the bin file was from kennie belle that he got when the turbo and motor were upgraded, however he had a 2bar map at the time and stock injectors
moates told me to use the rr58_v14 xdl file to datalog
the cpu is a 7749
so i should contact code59 and see what they say?
Just read through thier aggrement to terms of use, if you agree with it, then I don't see it being a problem. To verify you can contact Turbodig or one of the other admins and check with them.
code59.org
derrin
Post by derrin »
Thanks for the info Six
went and programed $59 to the chip and i roughed in the vehicle last week, im getting the ostrick this week and doing somemore.
No problem, just remember to post up the tune, to share with the rest of the community. ;)
