Who Needs An ADS or ADX?
the ECM portion of A072 is nearly identical to A094, so that file shouldn't take too long to get functional. it looks like there might be a typo or two that will need testing, like the A072 document claiming that the ECM's ID is 4F instead of F4.... I don't know if I've ever seen an application that uses 4F, but I've seen plenty that use F4.
https://www.dropbox.com/s/g4h6gc2sjv9wwxj/A072.zip?dl=0
here is a ZIP containing 4 files, 2 are for TP V4, 2 for TP V5. the way these early 3800 PCMs communicate is certainly different. the document states the way they connect includes responding to a message sent out to an ALDL device, which will stop normal communications going to and from the BCM. if that is the case..... it will be difficult to do with V4 other than spamming that command out and hoping you get it into the window the ECM is looking for.
with V5, you can monitor for the message from the ECM, then send back the correct one immediately.
however... I don't know which device ID I need to setup the command for, so I put 4 of them in each file(4F, F0, F1 and F4). the difference between the two files(for V4 or v5) is that one is setup to communicate with a "4F" module, while the other is setup for "F4". one of them should get valid data from the ECM, the other shouldn't.
Thank you for the help. With this not being a very popular application I figured that it would be forgotten about.
I tried the two V5 files, both seemed to communicate somewhat, but the data looked off. I am not sure what the best way to give you feed back on the definitions is. I recorded a short log file for each so to give an idea what the data return is. Please let me know if there is a better way to give you feed back or if there is other information needed.
https://www.dropbox.com/s/ss4u3mgfw3cms ... 4.zip?dl=0
1989 Buick Reatta with a Series III supercharged 3800 bolted to a F40 six speed transmission
The ALDL line on this vehicle has a body control module on it, and the command/response flow is a bit different form other vehicles.
The first thing the definition needs to do is listen for the F0 poll command. Details:
MESSAGE CODE $F0 IS USED BY THE ECM TO POLL FOR THE PRESENCE
OF AN ALDL TESTING DEVICE. IT IS TRANSMITTED FROM THE ECM
WITH THE FOLLOWING FORMAT
- MESSAGE CODE = $F0
- MESSAGE LENGTH
- SUM CHECK
IF AN ALDL DEVICE IS PRESENT, IT WILL RESPOND WITH THE FOLLOWING
MESSAGE:
- MESSAGE LENGTH = 85 + 0 = 85 = $55
- SUM CHECK
ONCE IN ALDL MODE, THE ECM WILL CEASE TRANSMITTING THE NORMAL
MODE MESSAGES ($0A, $05).
For good measure, the definition can send a silence command on the line to quiet the BCM before it can get clean comms from the ECM. It's not entirely clear what the BCM's device ID will be for your vehicle, however.
Once the ECM is in ALDL mode, you can request a normal mode 1 message.
MODE 1 (TRANSMIT FIXED DATA STREAM)
ALDL REQUEST:
- MESSAGE ID = $F0
- MESSAGE LENGTH = $56
- MODE = $01
- SUM CHECK
My guess from looking at the logs is that you're seeing cross-talk on the ALDL line.
- MESSAGE LENGTH
- SUM CHECK
MESSAGE:
- SUM CHECK
ALDL REQUEST:
- MESSAGE ID = $F0
- MODE = $01
- SUM CHECK
I'm really sorry to hear that you went through that. You and your family/friends are in my prayers!robertisaar wrote:I've had a LOT of personal stuff to deal with lately... lymphoma is a hell of a ride, and I'm not even the one that had it.![]()
I'll try and get to it tonight, I've got a lot more free time on my hands now than I have had for the past couple months.
yahoo started sending tunerpro notification emails into my spam folder... never realized when there were updates.
the battle was over before we even knew there was one... I'm told that's just how cancer is, something small and potentially easily curable snowballs into an unyielding monster really, really quickly. we had about 3 months to prepare for the inevitable, that still is gone in a blink.
![Sad :(](./images/smilies/icon_sad.gif)
that was my conclusion as well, but it's difficult to tell what exactly will get the line clear without begging/borrowing a tech1, otherwise some educated guessing followed by brute force. some of the documentation is close but not quite there.Mangus wrote: My guess from looking at the logs is that you're seeing cross-talk on the ALDL line.
such is life.IDcavy93 wrote:I'm really sorry to hear that you went through that. You and your family/friends are in my prayers!
those should be present in the TP definition downloads page.
http://tunerpro.net/downloadBinDefs.htm
ADX for a Volvo Penta GXI-F
Hi Rob,
I saw your post here and thought I would throw this out to you and see if you could offer any suggestions or help.
Do you know where I would find a defintiion file for a GM MEFI-4B?
Its GM Part number is 12584052
Its used in a 2004 GXi-F 5.7L
Not sure what other information I would need to provide, but let me know and I will dig it up.
Im fairly new at this so if you could suggest some good reading sites I will bone up on it.
Thanks in advance,
Thanks in advance,
Thanks for the link to files.
As a newbie to this whole thing I was happy to capture data using the AULL bin file from the provided link. However, my ECM cover and EPROM label read AULS (see links below for reference). Since the AULS bin is not available how accurate will my data readings be using the other bin files such as AULL, AULK or even AULP since these are the closest to a match? Will either of these files suffice for AULS? If not, what inaccuracies might I expect to encounter?
https://cloud.schichtel.net/public.php? ... c4613c97ed
https://cloud.schichtel.net/public.php? ... 9fe31ea9f9
a BIN isn't necessary to capture accurate data, only that you have the correct ADS/ADX for the BIN you are running.
if you have a PROM burner, you could copy off the AULS BIN that is on your current PROM. that could be your basis for a custom tune, otherwise you would need to decide which of the available BINs is the closest to your application and start with that.
MEFI 4B ADX file
Is an ADX file readable with any software other than TunerPro?robertisaar wrote:well, if they've sent along anything related to the datastream, it could be compared against the MEFI3 ADX I have to see if anything changed there.
From the output from Scanner Pro I have some information from the MEFI4B such as Hardware version, software revision, software release and calcheck. Do these values help at all in determining what the ADX should look like or what its close to?
Volvo Penta Gxi-F 5.7 with a Mefi4b
GMC 12584052
school costs money...
GMC 12584052
Newbie would appreciate some help creating ADX for MEFI4b
Hi there,robertisaar wrote:i have an ADX for a MEF3 unit, but I have no idea how similar they are.
Just stumbled over this site, searching on how to read diagnostics from my MEFI4b ECM.
Unfortunately I don't have the protocoll definition for the MEFI4b, so I would like to try the MEFI3 ADX mentioned in this thread.
@robertisaar: could you please send me the MEFI3 ADX?
@All: has anyone got the protocoll definition for MEFI4b?
Many thanks in advance!
Regards
Uli
Re: Newbie would appreciate some help creating ADX for MEFI4
The MEFI4 has a lot more features than the MEFI3 so an MEFI3 definition would probably not help very much. I think the MEFI4a and MEFI4b are the same except the 4b has CAN bus (not certain if this correct). One source for the MEFI scanning and tuning software is OBD Diagnostics (MEFIBurn.com).unipro wrote:Hi there,robertisaar wrote:i have an ADX for a MEF3 unit, but I have no idea how similar they are.
Regards
Uli
If you just want to scan: http://mefiburn.com/mefiscan.asp
I do not think there are any truly "public domain" definition files available.
Is your engine a GM RamJet or a marine application?
Charles
Hi Charles,
Thanks for reply!
My Engine is a Volvo Penta 5.0 Gxi-E, so it's a marine application.
Earlier in this thread I saw robertisaar offering the MEFI3 ADX to somebody else.
As I want to give it a try (and learn more about EFI Diagnostics): I really would appreciate if robertisaar could send the definition file.
Regards
Uli
Thanks for reply!
Regards
Uli
if it is the OBD2 unit, you'll need a cable capable of reading the VPW stream it likely pushes out.... I ASSUME it uses a standard OBD2 PID request system the way the full OBD2 implementations do, if so, I would think any basic cable would work. a lot of software options, including the OBD2 plugin for tunerpro.
I took my 16 pin aldl cable plug apart and noticed that there is nothing connected to the #2 pin or the #13 pin or the #16 pin .
Is this correct ?
Because my 16pin plug in the truck has connections in the #2, #13 and #16 pins.
Pins 4&5 have have wires/something attached to them on the usb cable and in the truck plug. So I think those should be good.
But why are those pins left empty on the aldl usb plug ??
[/img]
Is this correct ?
[/img]
for your application:
2 is one of the serial data wires, looks like class 2 VPW. pin 9 is also a serial data wire, the normal UART setup as used in most 86+ OBD1 cars.
13 is a circuit that runs to the transfer case.
16 is a 12V feed.
for an OBD1 application(that just has an OBD2 connector, as some 94-95 applications did), not a problem. for an OBD2 application, unless the PCM communicates over the UART link(fairly rare, usually only for aux stuff), it's not going to cut it.
16 is a 12V feed.
So to clarify.
Dash plug has obd2 pin out but is actually obd1 connection.
Usb plug has obd1 pin out.
Vcm under hood is obd1 but inside obd2 housing.
If I re wire usb plug to match the pin out of the dash plug will I be able to connect ?
I have nothing to lose at this point. I can't return the usb plug so if it doesn't work I am out $75. Would have been nice if the manufacturer of this plug stated that it won't work with 16193495 VCM-a 1995 4.3 engines.
your truck is actually more OBD2 than 1...
the data link connector carries a VPW(class 2) datastream, might be able to give a UART stream, the VCM is OBD2(or OBD2ish, at least).
starting in 93, certain 4.3 S/T trucks got some variant of it. the more common one is the 16184738, which seems to have been used 93-95, then 95 got a one-year only unit, the 16193495 you have, then 96 got another one-year deal....
the ALDL index lists a couple of VCM streams, but they're all for LB4 engines, not L35. the L35 streams that are listed are apparently for the more common '7427 type PCM that was also used with the 5.0/5.7.
85 Vett ADX file
Looking for an ADX file for a 870 ECM $1f for Tuner-pro RT, L98 TPI 4 + 3 Doug Nash 307 rear
should be able to just download the 1F ADS and import it into tunerpro V5 and have it functional.
808 VN commodre .bin .xdf .adx Data tracing
Hi, I am new to all this. I have TunerPro RT V5 and using a Moates APU1 Autoprom. I am having heaps of trouble connecting to the ecu and reading data. I found a BIN XDF and ADS file online but no idea if they are the right ones or not. I tried to enable data tracing but cant get it to work. Can anyone point me in the right direction as to the right files to get, and how to get it all working properly? Vehicle is a VN Commodore manual with an 808 ECU Thanks
most of the moderation team from pcmhacking is actually on here as well...
The1 looks to have posted here most recently, so I'd point you towards his direction.
http://tunerpro.net/forum/profile.php?m ... ile&u=2409
