shindengen ECUs
aphichart
shindengen ECUs
Post by aphichart »
how to hack shindengen ECUs
decipha
Re: shindengen ECUs
Post by decipha »
first you will need hardware to interface the ecu and read out the stock binary
once you've read it out you will then need to find a disassembler for that ecu processor in order to read the code
you will then have to go through the code and figure out the algorithms in order to create a definition file for it
here is a brief description of the process for fords, same applies for all ecu's
http://www.efidynotuning.com/dis.htm
fangia
Re: shindengen ECUs
Post by fangia »
this is hảdware , use mcu upd 70d3577 /FG4
fangia
Re: shindengen ECUs
Post by fangia »
peter 62 ,, i sent messenger to u ,,inbox
Andre Chee
Re: shindengen ECUs
Post by Andre Chee »
I have finish read this bin file
trongzen
Re: shindengen ECUs
Post by trongzen »
Can anyone show me which device to use to read this ecu shindengen bin file. Thank you so much
Satria12
Re: shindengen ECUs
Post by Satria12 »
Andre Chee wrote: Fri Jan 31, 2020 5:01 am I have finish read this bin file
How to read ecu from backdoor pin? Do you have diagram circuit pin?
Satria12
Re: shindengen ECUs
Post by Satria12 »
peter62 wrote: Fri Nov 15, 2019 5:38 pm backdoor or via front pin??please email
thanks
Can you help me, show your diagram circuit pin to obd via backdoor? Can uou send email? Thnkyu
Cokie cokie
Re: shindengen ECUs
Post by Cokie cokie »
Satria12 wrote: Tue Jun 08, 2021 11:11 am
hubungi saya di Osatriadi@gmail.com untuk shindengen
fangia
Re: shindengen ECUs
Post by fangia »
decipha wrote: Tue Aug 06, 2019 12:25 pm first you will need hardware to interface the ecu and read out the stock binary
Now, can write via k-line
