Dual Ostrich2 for 16 Bit Bosch MSA ECU's
paulserk
Post by paulserk »
Hey friends,
I discuss already in ecuconnections.com...
I see in tunerpro rt, that there is a checkbox for 16 Bit dual Emulator Support.
Can I use 2 Ostrich 2 emulators for 16 Bit Bosch MSA15 ECU's (one high and one low-byte eprom?).
Will I also got a tracing of the memory-adress, in 16 Bit mode?
Cheers
Paul
Tracing is currently broken (no ETA on a fix), but provided you can find an adapter that takes 2 8-bit emulators, and you can find the proper definitions, yes, this should work.
BrendanSmall
Post by BrendanSmall »
Tracing is broken?
Tracing is broken in dual emu mode.
BrendanSmall
Ah, gotcha :D.
paulserk
Post by paulserk »
When will work tracing in 16 bit mode work? Do you work on a fix?
prj
Post by prj »
Bumping this...
Could this be done? Pretty please?
I can make the adapter, it is easy, but because TunerPro is closed-source I really only have two options with the software:
1) Write my own
2) Hook TunerPro
Neither are very appealing...
passuff
Post by passuff »
Is it possible to emulate PSOP44 29f400 (EDC15) with two ostrich?
What is with tracing, is it fixed now?
Rhinoman
Post by Rhinoman »
Is the 16-bit tracing fixed now?
