Chip offset on Ostrich
89 Iroc Z
Post by 89 Iroc Z »
I am not sure if this will be added when ford support is added or not but I'll suggest it anyways. It would be great if you added a feature to program an offset to the Ostrich for the ford chips which are 64k and the binary is 56k so an offset of 02000 is needed. It would also be great to make a small utility that monitors a binary file of user choice and when changes are made to the file it automatically updates the Ostrich. So you could use on the fly tuning with other editors and applications that don't support the ostrich.
Keep up the good work.
Thanks.
