I have a '93 LT1 that was swapped into my jeep. It has the stock injectors in it. One of them in the right bank is leaky so I want to replace all of them.
I happen to have a set of ford injectors with the following specs:
Part Number lbs/hr cc/min grams /min PSI
XR3E-C5B 25.9 272.2 195.8 43.5
The only tunable parameter I see that relates to injectors is the injector flow rate. There is no Injector offset vs battery voltage table. Is this correct?
'93 LT1 injector replacement
