How to select Bin number for TunerPro
83 Gman
Post by 83 Gman »
When I open TP I have no Bin # showing up top but I do have the correct XDF file. When I select the file button the drop down menu has "open bin". When I select that the next screen is EBL P4 Flash/ User Calibrations. No Bin calibrations are shown.
How do I add a Bin file to that area?
I know the Bin # I want to use.
You need to open the folder that has the binary file in it in order to see the file you want.
83 Gman
Post by 83 Gman »
I don't know where that folder would be.
Look in the folder where you saved your .bin file.
83 Gman
Post by 83 Gman »
OK found it.
Another question. When you select from File on WUD to a VE learn and select the file you want to learn to. Is there a way to prove this is the file being used as the VE learn during a data log ?
