XDF and ADS/ADX files for a 1988 305/350 TPI.
dlwharleyman
Post by dlwharleyman »
What do I need. I am new to this type of engine in a custom car. The car is a 74 Jensen Healey. The TPI, engine and 700 R4 tranny setup came from an 88 Camaro.
Originally the engine was a 305. At some point the engine was changed to a crate 350 with the original TPI. The ECM may have been reprogrammed since the previous owner use to drag race the car. I removed the ECM and here's what I found.
ECM is apparently for a 305. Outside of the ECM box says GM/AC
D 88999194 LC21 490706298 GR 3 670 CG ESCM REMAN USA.
The ECM is 1227165.
The EPROM says AKFN 2178.
Removed the MEMCAL (?) and the chip is marked 1606930. Online info says chip should be a 16082177. Couldn't find any info on the 16069300.
''88 uses the $32B defintiions. For data logging, you can use the 1227165_6E.ads/ADX. You can also upload and use a $6E tune and use the full 6E definitions, but you'll need to unplug the cold start injector when doing so.
