chevrolet corvette
AALLEEXX
chevrolet corvette
Post by AALLEEXX »
Have problem with CHEVROLET CORVETTE 2000 year production, engine 5.7l.
Vehicle good start and engine work if vehicle dont move. If i try to move and speed become nearly 2 km/h ---engine shut down.
If i start engine,selector of transmission put in N position---engine good work in all range of rpm.
If i start engine,selector of transmission put in N position----take up vehicle and manually begin to rotate rear wheels-----engine shut down.
I look signal from Vehicle Speed Sensor----very good and correct.
Then i cut yellow wire from VSS to PCM ---vehicle begin work but there is no info on spidometers.
So i think problem by the channel of VSS
There is no DTC in ENGINE and TRANSMISSION. Only one DTC present----relay of ACC (AUTOMATIC CONDITIONER)
-----may be it a problem with PCM.....??????
------ may be it ..............................??????
May be somebody have the same problem ???????
Moving to general tuning forum. Unfortunately I'm not sure you'll be able to get much help here in these forums. Your car is a bit on the new side and isn't yet supported by TunerPro.
